Resolved 1G No power to obd?
The issue is somewhere between the last place you had voltage and the first place lost voltage.
So get out your meter and start following the circuit diagram. Check from one end to the other. It is between "last and lost".
E-19 - DIAG CONN
There are other signals present on the DLC connector like the VSS, cruise control, and TCU is present but the ECMTuning like is correct W.R.T. the 1G ECU connections. The three pins are Data, Mode, and Ground.
The ECU uses pin 1 as a bidirectional data line. In the default mode the ECU outputs either current fault codes or a heartbeat on the data pin. In diagnostic mode (grounding the mode pin) the ECU switches to datalogger mode, inputting commands and outputting responses on the data pin. The ECU also uses the mode pin (and the timing check connector under the hood) for setting base idle speed and and setting the base timing via the CAS.
If the ECU doesn't output any voltage on pin 1 it's either not turned on (via the MPI relay) or it's dead.
See: https://www.dsmtuners.com/threads/1g-basic-ecu-mpi-circuit-function.435961/ for diagnosing this.
