1G No power to injectors
EG Hatch
99
5
Oct 24, 2009
Austin, Texas
Hi everyone. I picked up a mostly stock 1990 laser yesterday and it was running fine until I swapped in injectors and an ecmlink ecu.
I am measuring no power to the injectors, as well as none to pins 102 and 107. The battery backup and pin 63 both have constant 12V with ignition on. I tried swapping mpi relays and resistor packs for known working units, and I even put the stock ecu/injectors back in. Same problem. No burns in either ecu.
Help please as I am at a loss here.. I guess the CAS is next.
