General 1g n/a ecu in talon tsi?
Meinleat
57
Feb 19, 2012
Klamath Falls, Oregon
So yeah just bought this car about a week ago. The guy I bought it from just told me I wouldn't run and had sat for up to six years. I went through to get it up to running standards and then it would start but it was a very hard start so I checked more of the car repaired a bad ect sensor wiring job still no luck. Now I pulled the ecu today and took a look at it and noticed its Epsom but no knock board so I ran the numbers on the ecu (MD304481. It came back as a non turbo ecu, I'm guessing this is the cause of the hard start issue what do you guys think?
So what is the new car? I can't imagine someone would go through the work to adapt an 1G NA ECU to your 95 so I'm guessing some flavor of 1G.
A 1G NA ECU in a 1G Turbo will start usually but it's not going to run very well since the ECU thinks it has 210cc injectors and it really has almost 100% bigger ones so it's going to get almost twice the fuel it expects when it fires an injector.
I've converted a few NA EPROM ECUs in the past but the missing knock board is a good sign that it's still an NA ECU.
It's in a 1g, it acts like its flooding itself with this ecu. Do you have any turbo ecu laying around for sale?
