1g Intake Options
SinaiTSi
872
15
Aug 5, 2005
Misawa, Japan, Asia
I looked all over on the forums and couldn't find anything covering this exact topic, so sorry if it has already been answered.
I have a 1991 Talon TSi and it is completely stock. I'm planning on putting on a drop in K&N filter, getting rid of the aircan and a Dejon Tool or similar intake pipe. Right now since I have no other mods, I don't need a 2g MAF or a GM MAS, but down the road i'm planning on upgrading to either one. My only problem is that I want to save myself money down the road and I don't want to buy a new filter because the drop in and intake pipe won't fit on the 2g MAF. Would it be best to go ahead and get all of that at the same time and if so, could you give me advice on filter size and intake pipe sizing. Thanks.
Go to Dejontool's website and keep scrolling down under intake pipes and there is a 1g k&n filter to 2g mas adapter thing. This is from their site:
AFKN-2/1
1g K&N Filter to 2g MAS Adapter
with Side Mount and Front Mount IC's and a 2gMAS before the turbo.
AFKN-2/1
*The K&N FPIK for the 2g car is too big for the 1g
Use your 1g K&N to get great air flow at low cost!
1. 3/16" thick Lexan cut, drilled & tapped to bolt to your 2g MAS.
2. Comes with all screws needed, including 6 self drilling screws which attach the K&N
AFKN-2/1 - $19.95
Thanks a lot. That will save me money in the long run. One other thing, what size is the 2g MAS and the 1g MAS on the tube side (will a 1g intake pipe fit a 2g MAS) and how large is the stock turbo for when I order an intake pipe.
Here's a picture of the 1g MAS and you can see how little air could flow through it.
http://www.roadraceengineering.com/eclipsetech/1gmas/1gmas-fullopen.jpg
Here's a picture of the 2g MAS and you can see how much more it would flow than the 1g.
http://www.roadraceengineering.com/eclipsetech/2gmas/2gmas-sidehcout.jpg
The 2g MAS has a wider opening than the 1g MAS for the intake tube. You could be able to take a stock 2g intake and cut the piece off that connects to the MAS and leave enough on to connect to a slightly chopped of 1g intake pipe I guess. The standard size Dejontool uses for intake pipes is a 2 3/4" opening for the turbo. This should work for the 14b. As always, adding rep points for answering questions is always appreciated :thumb:
It will most likely be a while before you outflow the 1g mas. Id just pull off the stock aircan and replace it with a K&N that you can pick up from Advance for $45. You could even still get a hard intake pipe for your 1g mas and sell it when youre ready to upgrade. The 2g mas isnt a drop in, so unless you have an afc to tune it with, Id hold off.
Thanks for the info. guys. I can't wait until I'm a registered user. It's one of my lifetime goals, up there with shaking Big Bird's hand and swimming in a giant bowl of jello.
  • For sale 4G63 Frontline Fabrication V2 Billet Valve Cover
    Frontline Fabrication V2 Billet Valve Cover $750 + shipping & paypal fees* swivel AN fittings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
