1g intake install.
TaloNKiD505
225
Dec 11, 2002
I just bout my 1g dejon intake. I put it on with no problems. Car started up fine but then seemed to have alot of idle fluctuation. The car has alot better throttle response but will stall out occasionally when coming to a stop. I put a valve breather on the 1 line that connect to the stock intake, but cant on the new 1. I thought that might have been the problem but it isnt. If you have any idea what the probelm might be please let me know so i can fix it LOL.
Thanks in advanced
matt
might have something to do with the mas disconnected...i know it caused problems on my friends 1g laser....
Things to check:
1) MAS plugged in?
2) BOV recirc tube on?
3) Any air leaks between MAS-->Intake-->turbo?
yea every thing is connected no leakes. im gunna double check the bov tube because it doesnt sound like its venting a bit. if not ill also adjust the idle to see if that will help any.
