1G in a 2G CAS w/ Magnus/RRE Harness - Long pigtail of any benefit?
High PSI
145
17
Oct 21, 2004
USA, Australia
If you're using the RRE/Magnus plug-and-play harness on a 1G swap into a 2G, is there any benefit of getting a green-top with a long pigtail (89-90) over the plug type harness (91-92)?
This is going into a 1995 GSX BTW.
EDIT: Just found the answer to my question on the RRE page:
RRE's Eclipse New Products
"It connects to a 91-94 1G Eclipse CAS"
"It does not work if you buy a '90 CAS"
Are you talking about the 2G Eclipse 1G Motor Swap CAS Harness? I am doing this in my 95 gsx and i am going to use a black top CAS.
Yep - doing the same to my 95 GSX. I believe the black top is best but they're a bit harder to find. From what I gather the green top will work fine but you need a plug type.
Yea i found my black top on here. Put up a want to buy ad in the classifieds ads. I haven't got mine installed on my block yet but i will soon.
This is what i was thinking too, can anyone confirm? I have a 90 green top with a plug and i was planning on using it with a 97+ wire harness... will this work? i thought it would :confused:
You need the RRE wiring harness. On one end it has two plug in's and those go to the stock cam and crank hook up. Then on the other is where the 1g CAS will plug in. i used a black top they are the hall effect type. The green top is a optical type. I have the wiring harness and black top just need installed.
Yeah i plan on getting the harness once i get closer to turning the car on but my set up should work, right?
I put one up and I've gotten a ton of PM's but they're all greentops. I'm not too bothered either way...the black top is just "theoretically" better. The actual performance difference is most likely negligible if apparent at all.
ANy 1q CAS will work. If you get an 89-90 you have to wire it in yourself. With a 91-94 you can use an RRE/Magnus harness. The harness can work with a 95-99, you just have to let Magnus/RRE know what year car to build the harness for.
