rabenne
- 1,803
- 843
- Apr 21, 2006
Racine,
Wisconsin
so the car is not getting spark... I turned the cas by hand and can hear injectors clickin and the fuel pump cycles... I have battery voltage at the red wire... The ground is questionable.... with the key off it shows continutiy to ground as .9 ohms, but when the key is switched on the cont. goes to around 18 ohms... I was wondering if this is normal... also, The ecu is getting no rpm signal... any help appritiated... thanks
