1g head with 2g water pipe
money42211
67
Jul 21, 2012
cumberland, Maryland
Why can u use 2g water pipe with a 1g head.all u have to do is get a rad house to go over the 2g water pipe and use 1g T housing
Asking I think it would work y wouldnt it 2g pice just shaped little different and different water line spots.
I use a 2G radiator, with a 1G water pipe that goes across the front of the block. If you have a 2G pipe, and a 2G thermostat housing it should work.
I do have a 2g t housing but it dont bolt to the head its different
Come on guys post ## input really wont to no if that would work found a hose to fit
Because the inlet angle of the water pipe for the lower radiator hose is way wrong and you won't find a hose that will work.
And if you think you have, I'd love to see it.
