1g head on a 2g?
Gearhead4G63
137
May 14, 2012
New Orleans, Louisiana
I have a 1g head that's ported and polished with 262 cams and upgraded rocker arms springs and lifters., I want to put it on my 2g, what's all the mods I have to do to get it to work for me, I know I have to change the goose neck and th cas, anyything else also how do I go about changing them? Just a straight swap?
In a nutshell:
1G water pipe
1G thermostat housing
1G intake manifold
1G TB (recommended)
That's just for you, assuming you have the 97-99 CAS still on your car.
NOTE: With the 1G manifold, you lose your MDP sensor. If you plan on keeping your EGR, read RRE's writeup. If you are okay with getting rid of it, get a block off plate or make one. Your coil pack will probably have to temporarily be relocated to anywhere of your choice until you get a 1G coil pack and bracket. Not a necessity though, mine's been on my strut tower held on by one bolt for years now. You can also put it on the intake manifold bolt holes with the throttle cable. I would recommend a custom or 1G bracket though, and 1G coil packs.
