1g guage pod question
PxIxSxTxOxL
32
Aug 13, 2008
chesterfield, Michigan
Just picked up a 92 talon awd. It's stock and Im looking to retain the stock look of the interior. Just wondering if they made guage clusters like this for the 1g. Ive been looking and so far came up with nothing. Any other imput on a different pod is welcome.
You can replace the stock temp, oil presure and fuel gauges with aftermarket gauges. they fit with just a hair of trimming there is a post on here about it if you search custom gauge mounting you will find it. Otherwise its just piller or vents.
There isn't one like you posted for the 1g but there are center vent gauge pods which look a lot more factory then A-pillar pods. This VI center vent gauge bezel is high quality and includes mounting brackets. No tape or glue required. If that's out of your budget they sell simple metal plates which you glue in for much cheaper.
Also like socostsi said you can replace the factory gauges, here is a some threads for that:
http://www.dsmtuners.com/forums/newbie-forum/381540-after-seeing-factory-cluster-aftermarket-gauge-decided-try.html
http://www.dsmtuners.com/forums/appearance-interior-exterior/381252-dash-gauge-install.html
http://www.dsmtuners.com/forums/appearance-interior-exterior/379396-cluster-ownage.html
Hope this helps!
Hope this helps!
+1
This is about the best it's going to get. Sadly I enjoy the Dash Gauge mounted ones, but the ones for the vent are nice. If anything at all you can make your own custom adapter and cut it out for gauges to fit in the slot over your radio if you have an aftermarket one installed.
