Resolved 1G fuel pump constantly running and no crank
jw_55_55
108
Oct 3, 2005
Silver Lake, Wisconsin
Well i just got my car tuned and after about a week there was a short that was throwing a maf code. I would just wiggle the ecu harness and that would clear it up. So i thought if i put the ecu back in its location things would be fine. Well after putting it up my dash lights went dim besides the check engine light and seat belt light. Also now my fuel pump is constantly running and the car wont crank.....any ideas??? I do have an safcII for tuning and i wired it in myself. I unplugged the ecu and turned the key on and the fuel pump still is just constantly running?????
Solution
Found the problem....was the engine ground! hard one to diagnose since i had the car running for over month...anyways thats what it was!
well im going to check it over really well tomorrow! Any other ideas or areas to try....before i get into it tomorrow?
Ya there definatly has to be something crossing somewhere, unless you have leaking caps in your ecu. But bro what this about you getting tuned and didnt tell me, what numbers did you make? have you checked all your fuses
Well after i checked over and over everything still having the same problem...but got it to start and it was clicking from the fuel pump relay till it dies...sooo im thinking a bad ecu, ground, or fuel pump relay??
Solution
