1g fan wiring question
natertater
320
Jun 26, 2008
san diego, California
i have searched, and found mostly threads that pertained to 2g wiring, or slim fans. i am trying to wire in stock 1g rad fan back to how it should be, but using 2g plug, since the numb nuts i bought the car from hacked the harness instead of changing the plug on the 2g fan he put in.:ohdamn: anyways, this is what i have by looking at the wires behind both splices.
engine harness side to fan wire side
black = small black
blue/red = large blue
green/blue or brown = green
blue/black = black
i have a chiltons, and that thing doesnt really have reliable info.:aha: shoulda bought the haynes...oh well. im going to pull the pins out and redo the plugs as if they were stock, just trying to line up the wires so they work. that wiring above didnt work last time i ran car...:banghead:
just found out by browsing google, the fan plugs i have arent from a 2g, they are round plugs...so this is totally custom hill jacked...oh great.
These are pics of the stock 1g fan wiring. The wire colors on the harness side matches the wire colors at the plug on the fan. The wires at the plug on the fan split off in pairs. The Black/white and Blue/black wires go to the black thing on top of the shroud then, the wires go to the metal encased unit in front of the shroud. The Black and Solid blue wires go straight to the fan motor.
Hopefully, this helps.
thats the condensor fan right? not the rad fan? plus i have no white wires on my harness at all...just the colors listed above.
also, is there a way i could buy the harness plug for the 1g anywhere? i know parts stores are now starting to carry stuff that you could only get at junk yards before..but just trying to get feelers out there to see where i could get some.
guess i can check to see if the wires on the a/c fan match to what i sorta found out with other pin out mash up. the schematics show that wires are same colors in my chilton (who can trust that...shoulda got the haynes...)
Yes. I posted the wrong fan. Below is a picture of the Radiator fan plug.
Plug side....................Harness side
Green/black.................Green
Blue/black....................Big Black
Blue/red.......................Blue
Black...........................Black
kickin @$$ man..that really helps a lot. i wondered if the thick blue went to red (logically right, the bl/b being ground) but i have had that logic kick me in the teeth before you know? thanks a ton for the help!! now, to redo this plug...
oh, and plus 2 for rep man, i cant do it, but if i could, i would!
No problem. I help where I can.
heck man, too much work trying to splice in something that doesnt belong..just hard wired them together with crimps and taped them up. just waiting the 1 hr cure time now on the oil return line...crank them down, and start it up again, and see where this coolant leak is.
