Resolved 1G ECMLink v3 SD idle problem please help
niki_talon
67
14
Apr 26, 2007
Bulgaria-Burgas, Europe
Please help I've been trying to get my car idling correctly without any luck. Attached is a log and video of my idle, check it out and let me know what you guys think and what I do.
Thanks!
ECMLINK V3 SD IDLE PROBLEM HELP - YouTube
My Mods.
ECMLINK V3 FULL WITH SD
GM IAT
ZEITRONIX 3.5Bar MAP
ZEITRONIX Zt-2 Wideband
4G63T - 6 bolt
TURBO - GT35R
WISECO - Extreme Duty "1400 HD" Forged Pistons
MANLEY - Performance H-Beam Steel Connecting Rods
COMETIC - Head Gasket .051
ARP- L19 Headstud
BALANCE SHAFT REMOVE
ACL - Race "Tri-Metal" Rod & Main Bearings
BRIAN CROWER - 272/272 Cams
FERREA - Manganese Bronze Intake and Exhaust Valve Guides
SUPERTECH - Intake and Exhaust Valve Stem Seals
MANLEY - Performance Race Series Stainless Steel Intake and Exhaust Valves 1mm Oversize
MANLEY - Performance Race Series Valve Spring and TitaniumRetainers
VALVE JOB - 5 Angle
LIFTERS - 3G
PORT - Intake and Exhaust
TIAL BOV 50mm
TIAL WESTEGATE 41mm
FIC 1150cc
SHEET METAL INTAKE MANIFOLD
Stock N/T FPR
1g manual vehicles have 38 psi as base. The OP needs to take this into account for his global fuel % (which is currently off). Use the build in calculator and adjust the necessary values.
Do you have an ISC? If so, it may be bad (seeing ISCPosition at 0).
Your front o2 seems to be not reading correctly - are you sure that it is in good condition?
Have you done a boost leak test recently?
I thought your fuel pressure should be set at 43.5 psi. Someone please correct me if im wrong. This could be a big issue with your idle.
For this log I used N/T fpr.I will return 1G turbo fpr to see what happens.
Also I don't know why ISC read 0. I Test it works
I tried to adjust to global fuel correctly to FIC 1150cc Global - 61 and Deadtime - 330 but the engine off and getting worse.
I Test ISC it works cold read 80 hot falls to 0 :confused:
I use Zeitronix Zt-2 Wideband A/F Ratio Meter with Dsmlink v3
From Zeitronix Wire purple simulated Narrowband 02 Output directly to pin 4 ECU 02 oxygen sensor and Zeitronix Wire white Wideband analog Output directly to pin 15 ECU EGR.
I think this is correct.
Is that not an aeromotive fpr on your firewall?
Yes it's Aeromotive fpr not yet installed.
I just want to drive the car correctly :sosad: with dsmlink SD to go forward with tuning.
New log with 1G turbo fpr 38psi.
Video on bad or good ISC ?
Idle Problem bad or good ISC - YouTube
