1g dsm still running rich and sucking to much air
darkstar5456
207
Feb 23, 2010
Mitchell, South Dakota
ok frist let me say if I mess up my spelling don't bust my balls I am doing this thread on a phone but anyway I just put new n\t injectors in and she is still rich as you can smell the gas sputterd trys to die and I am sucking a lot of air I don't need thise could be the reason why I am still surging I am out of ideas and I don't even know where to start to try and fix this so if anyone has had this prolem and has fixed it let me know thabks guys sorry again if my grammar aint good on this thread:thumb:
sounds like a vacuum leak to me. as well as other problems. a faulty o2 sensor could cause you to run rich, so could a faulty coolant temp. sensor
Agree with the above post. Check for a vacuum leak. Spray some ether around the intake at all connections and the flange. Use as little as possible, short sprays here n there. You'll know where the leak's at when the RPM jumps up.
