1G CAS Trigger Plate Install?
YUPOK
397
30
Aug 13, 2013
Riverdale, New Jersey
Which way is the 1G CAS Trigger Plate supposed to be installed?
I have a 1G CAS Long wire on my 2G setup and just want to make sure the plate is in the correct way.
Yup, I cleaned it.
The CAS was sitting in a crate outside for about 6 years. Amazingly it still works but not sure if I put the plate in correctly after taking apart and cleaning and replacing the 4 wires. I can't find any good pics of it installed with the timing mark in relation to the flat on the center bolt hole. Car runs but rough and I want to make sure the plate is in the right way.
Also for clarity this is for the CAM angle sensor not Crank sensor on the 7 bolt.
Oriented like this. The two inner slots show you how it goes.
I thought there was one small notch on the disk as well oriented on an odd angle.
I don't see that in your picture though. This is what mine looks like.
https://www.google.com/search?q=DSM+CAS+trigger+disc+pictures&biw=667&bih=582&tbm=isch&imgil=szpmqQiWEtrO3M%253A%253Bhttps%253A%252F%252Fencrypted-tbn2.gstatic.com%252Fimages%253Fq%253Dtbn%253AANd9GcSHDrEbdMZi-V2PcDyxjTSXpuX4P9JDzfQ7ZdlEVyOGBg3ZBXYziQ%253B200%253B200%253BoujuI18N0QPDxM%253Bhttp%25253A%25252F%25252Fwww.roadraceengineering.com%25252F1gcasin2g-waveforms.htm&source=iu&usg=__ucnsa_fbHL8cpVzPD5HFc3IDurA%3D&sa=X&ei=dDlEU_HCK8X_rAe8v4CADg&ved=0CDQQ9QEwBg#facrc=_&imgdii=_&imgrc=szpmqQiWEtrO3M%253A%3BoujuI18N0QPDxM%3Bhttp%253A%252F%252Fwww.roadraceengineering.com%252Feclipsetech%252Fjustin%252Fcasdisk.jpg%3Bhttp%253A%252F%252Fwww.roadraceengineering.com%252F1gcasin2g-waveforms.htm%3B200%3B200
Ah I see it now, the second picture has that orientation notch off to the left, which makes sense, mines off to the right. Hopefully explains why it's running rough.
For anyone having the same issue, the link I have in addition to the above photos is how the disc should be installed looking at the CAS with the cover off.
Thanks!!
  • For sale 2g Remanned Mitsubishi 2G AWD Auto Starter
    Remanned Mitsubishi 2G AWD Auto Starter $60 + shipping & PayPal feesYou must be registered to...
  • For sale 4G63 NEW JDC Titanium Dipstick Handle
    NEW JDC Titanium Dipstick Handle $55 + shipping & paypal fees* these are $110 online ( save 50...
  • For sale 2g NEW OEM Idler Pulley & 2G Tensioner Pulley
    NEW OEM Idler & 2G Tensioner Pulley $70 + shipping & paypal fees* idler pulleys are about $89...
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
