1g BOV install on 2G GST
Status
Not open for further replies.
Knaackers
65
Jun 24, 2004
Menomonee Falls, Wisconsin
I want to install a 1g BOV on my 97 gst. Does anyone have this mod? If so, what needs to be done? and will it be able to run 18psi on factory turbo?
buy a proper UIP and then it will work fine. You have to change the airbox out for an open element filter to get enough rooom for a better UIP, or you can waste 30 buck or so buying an adapter that will be discarded as soon as you get that better uip.
please don't try to run 18 psi on the factory turbo... 16 psi max and you will get much better performance.
Status
