Trying to install 1G BOV on 2G Eclipse
TurboSpider
223
17
Nov 2, 2015
York, Pennsylvania
I know this has been discussed to death before, however many of the older threads had bad links that lead to dated websites and such. I just bought a 1g bov uncrushed and plan to replace my 2g plastic junk with it. The line going into my intake is the stock rubber intake. I know I will need a gasket. Does this look like the right one? http://www.ebay.com/itm/1G-DSM-Mits...ash=item2809d956e4:g:5UgAAMXQLw1R3f1G&vxp=mtr
And this adaptor? http://www.ebay.com/itm/EXTREME-PSI...ash=item1c55cb8015:g:f6kAAOSwaNBUke-H&vxp=mtr
Besides those two things, do I need anything else. I assume the other end of the stock 1 g bov will attach to the factory recirculator line with no mods.
That's the adapter, and the right gasket, everything will bolt in and recirc just fine!
I actually just upgraded to a HKS SSQV 4 and took this setup off my car, too bad you already bought a BOV, as I'd sell you the billet flange, with the bov already gasketed/attached and Boost leak tested! Once you separate the BOV from the flange, you gotta use a new gasket.
Boost leaks love to happen at this plastic pipe/bov flange junction, so make sure it seals good!
