1g AWD wheel bearing help needed (with pics)
soulcontroller
61
Jun 11, 2002
ok, im attempting to get to my rear passenger side wheel bearings, cause they are shot.
i take the rear 3 bolt axle off the hub and get the hub out.
no problem there. probably going to take it to a shop and have that bearing removed, and the new one pressed in.
removed the oil seal.
now, the inner wheel bearing seems to be stuck in the trailing arm (i think thats what its called). my question is how do i remove it?
you can see it there. i dont really know how to get that out, or how to get a new one in there. if you guys have any suggestions for that, let me know i know thats what the source of my problems are.
finally, these are the bearings i have. part numbers 511014 and 511015 for the bearings. oil seal in the middle.
the outer bearing doesnt look at all like the one in the hub, im wondering if its the wrong one?
what a frustrating day. heh.
TIA guys.
md
ok. got the shaft out. popped out the inner bearing, now the outer bearing is stuck on the shaft. anyone have any pointers as to how to remove it?
Take it to the same shop that's going to press the other bearing. If you don't have special bearing removal tools and a press it can be a royal PIA! It's worth the couple of bucks to have them removed and then get the new ones pressed properly.
Rick - '91 GSX :dsm:
i ended up getting it off....
now i just need to put in the new and bolt her back up! thanks for all the help.
to anyone wanting to do awd rear wheel bearings at home, just take it to a shop LOL.
i guess its not so bad once youve gone through it, but then again what is.
