1g awd trailing arm
jw_55_55
108
Oct 3, 2005
Silver Lake, Wisconsin
I have been looking for the rear trailing arm bushings and energy suspension doesnt seem to sell them??? Unles the rear control arm set has it in it?? IF anyone could give me the link to where to buy the rear trailing arm bushings is I WOULD APPRECIATE IT!!! thanks
I used the set up from Jay racing.
doesnt jay racings have to be welded on??? and how hard was it to get that rubber bushing out of the arm??
i would like to just replace the stock bushing that i had to burn out when taking of the bushing for the rear toe alignment, but i cant find it???
You should be able to get those in either a Prothane or Energy Suspension rear kit. I can try and get a part number later if no one can chime in, I'm about to leave for work.
Also I burned out the bushings for the active toe, there was no way I'd be knocking out that with a hammer. (trailing arms had some rust :() I then welded in the insert to the arm.
How come energy suspension makes 1g kits but prothane doesn't? I want to pick up a master kit and energy suspension has one with front and reasr sway bar end link and control arm bushings along with sub frame bushings.
