Resolved 1g awd 5 speed- throwout bearing "snout" dimension
erikoberdorfer
183
64
Sep 10, 2007
Akron, Ohio
I am looking for a measurement of the "snout" on an awd dsm 1g 5 speed transmission (91 and up) where the throwout bearing rides. The collar that is on the bell housing where the throwout bearing rides has a length that i would like to verify. Please, can anyone measure this and share it here? Mine is damaged and I am making a sleeve to go over the damaged aluminum one. Due to the damage, I can't accurately measure the original / oem length.
Thanks in advance!
Erik
While our goto GURU is injured I will try my best to help but I am not the "expert".
I just put this 91 transmission back together so this measurement should be what you need.
I don't understand the aluminum part. The snout is steel.
Here is what this 91's numbers are.
41.55mm
1.6355"
Thats as close as I could get with the calipers for the length of the snout.
Marty
Sure thing. No problem. That is what this forum is all about.....help, and I am proud to be part of that!
