throwout bearing
power=dsm
268
Aug 22, 2003
Well everytime i push my clutch peddle in i hear a grinding noise from the transmission. I'm pretty sure it's my tob. I was just wondering if i don't change it right away what damage can i cause to my clutch which is fairly new 12000miles act2100?
It could be your throwout bearing. Are you using the OEM TOB?
Did you loctite your pressure plate bolts? I'm willing to bet one of them has came loose..
sorry it's not a grinding noise it's more of a crunching sound, also i feel a tiny bit of Resistance in my clutch peddle?
I will eventually start eatin into the pressure place when the bearing eventually locks up...... i'm in the same situation...AGAIN :notgood:
it will not get any betta, it will start grinding, the can try adjusting it, to slow down the process, but then it will eventually stop going into gear.......i'm currently at stage 2 of this process :dsm:
