2G 1995 Eclipse won't come out of gear
Slillo88
Oct 14, 2021
AZLE, Texas
I have a 1995 eclipse 5spd turbo. On my way home the car got stuck into 4th. While sitting on the side of the road lots and lots of jiggling was able to get it out of fourth gear. Shortly thereafterwards I had hit fifth and it slipped into fifth and I have not been able to recover it from there.
Also I noticed when I got it home my shift linkage was super loose when I disconnected the linkage I still could not get the transmission in or out of gear
Pull the three detent bolts and springs and balls on the front side of the trans (radiator side). Using a mirror or camera you can now physically see the shift rails inside the trans. See if alll 3 are moving. If you break a shift rail end that rail wont move and the piece can get stuck and block other rails. At least you can rule out the rails easily. If you move the shifter and a rail doesnt move you've definately broken it. Did you do a hard 3rd gear shift right before this happened?
I agree with pauleyman - sounds like a shift rail problem.
If you try to move the shifter arms on the tranny by hand, do they move or are they bound up?
I was slowly accelerating up an on ramp behind a big rig and I never push hard shifting
This picture is missing the top bolt out of the 3 but it shows you where they are located.
There are three bolts in a row towards the front of the car. They're towards the far passenger side of the trans. The only thing behind them is a spring and a ball.
I'll be trying this tonight anything in particular I should be looking for
I've removed all the bolts all that came out were spring so I'm going to go see if I can find a magnet to see if I can remove the balls
Yes they should come out with that. If you wiggle the rails they may also fall out. Don't lose them.
