1995-1996 Bumper with 1997 Tail lights?
95-99 Eclipse rear bumpers require 95-99 Eclipse tail lights.
95-98 Talon rear bumpers require 95-98 Talon tail lights.
The mounting points are same regardless of weather you have an Eclipse or a Talon.
Fill out your profile so we know what car you have.
I'm sure he was referring to the lights, but just fyi the mounting points for the bumpers, eclipse and talon, are not in the same locations. The center mount points are, but the sides are in different locations. Just posting in case this is relevant to whatever the op is trying to do.
Good point! Depending on the car, you'll just have to drill 3 new holes on the center tail light when doing a conversion and you can clearly see where you need to drill.
