1992 Eagle Talon Refuses To Run
Shank666
Nov 12, 2012
Cobourg, ON, Canada
That's not completely true.
The car starts up cold, goes vrooooooooom then dies
(If you touch the gas at all before it warms up it dies.)
Do that about 3 times and then it will start to idle propper
Idle comes down to a perfect 750 when it gets warm but after you though the gas the idle dips down to 450 and stays there.
Whenever driving and pushing in the clutch the car dies. Starts right back up but still shouldn't be doing this.
Check engine light is on.
Tried to use volt meter, test light etc to read the obd1 Plug.
No power to plug, tested grounds and made sure.
Changed fuses, 1 blown, idles slightly better could just be my imagination.
Light still on
Engine still dies
Plug still doesn't work.
What do I do?
