We're on Boost
- 3,135
- 1,539
- Aug 25, 2007
Seattle area,
Washington
Last night I took a bunch of pics of my GM MAF that I bought new from MAPerformance in 2009 and it is supposed to be a genuine GM MAF.I'm starting to think this isn't a GM original MAF
These pics might not do you any good, because when I look online, I see that some of the cheapo fake "compatible" MAFs look pretty darn much like mine. But here they are anyway
I would say this MAF worked right on "nominal" (accurate). My AFRs in the high power part of the range were 10.5 with zero tweaks to it in the ECU+. So close I didn't bother to tweak that part of it. I did tweak the idle range a little to make that part richer.
The "target" AFR that Jeff Oberholtzer had in mind when he burned the chip for the ecu was 11 at high power. Close. I had the ECU+ translating to 2g Hz, because Jeff said the 2g scale would be more suitable for high power. So that's what we did, that's the scaling that he put into his DSMchips ecu for me.
That's the setup you see in the Specs and Mods under that other profile of mine, the one that's called "up through 2015".
Switching back to a stock 1g MAF would have the advantage of, you kind of know where you're at with it, so it should be easier to get the rest of your system back to nominal operation. Assuming that the old 1g MAF is working right. It'll become your limiting factor once you hit about 2000 Hz, which is not hard to do once you have a 3 inch downpipe, 3 inch exhaust, and no cat.
Switching to SD would make sense because that's what you are going to do anyway, probably.
In these pics I've only taken off the air cleaner. The short pipe that goes to the 14b is still attached to the outlet side of the MAF, and we are looking through that pipe in the last pic.
! But all joking aside and while that does work there’s absolutely no reason to do that in the year 2024 when working 2g maf’s are 20 bucks and speed density is obtainable for under 100 bucks given you have the engine management for it. Not to thread jack but I like those trips down memory lane…and I shouldn’t talk as I was doing that in 2017 when 2g maf’s had hit that disposable price.
But IAT not working must be a problem with wiring or the ECU.
