sakroda
- 247
- 39
- May 3, 2016
İstanbul,
Europe
Hello
I have searched on dsmtuners but i could not find clear answer that s why i had to create a new article..Actually I had a plan about ABS retrofit. By the way i have 1990 talon so you know they have different cruise control system between 1990 and 1991. So for my abs project i need space for ABS pump that s why I can not use CC with 1990 so I bought 1991 CC system not CC ecu just bought CC mechanic parts..I looked at the 1990 CC ecu and it has 20 pins otherwise 1991 CC ecu has 26 pins Actually I never seen my CC ecu before i mean I don t know howmany pins CC ecu uses? anyway My aim is replacing 1991 CC to my car..I guess 1990 Talon's CC is fully electronic controlled system I read on dsmtuners..Can i do this replacement on my car? M CC uses same port as 1991 they are LY LR LW LB if it possible I think 1991 CC needs vacuum line how to get this vacuum line to 1991 CC..I hope you can help me thanks.
I will try the CC when i got the pocket it s still on the way
