1G 1990 cruise control actuator issue
sakroda
247
39
May 3, 2016
İstanbul, Europe
Hello
I bought 1990 CC system with throttle cable but actuator harness socket is removed before i bought it so I made a new male socket then i plugged it to my car but i could not engage with the system.No green light and i could not see orange light on the column switch after then speedometer is gone:) after unplugged the CC socket, speedometer is came back again but i want you to know one issue before i bought 1990 CC I had 1991 vacuum system it worked very well i saw green light and orange light but 1991 system did not work very well because CC increas the speed all the time:) but when i the press the clutch or break pedal, it s was deactivating...Please have a look the my video..What went wrong?
Hi
Today I plugged the everything and it worked fine but It worked on my 35th try..I turn the column switch for CC so light on and it goes suddenly and i see light orange bulb.. it does not engage every time i try:( maybe it s about speedometer reed..Do you have an idea about this issue? i will try with diagnostic
