Resolved 1990 tsi won't rev over 1500 rpm
pat white
252
225
Jun 10, 2017
West Bay, NL, Canada
My 1990 Eagle Talon TSi manual won't rev past 1500 rpm unless I pretty well floor it, it idles ok and starts normal.
Some background the car was running fine until the ECU died. I checked the MPI and it was fine, found caps in the ecu leaking , changed out the ECU with one from a 1991. (wierd that the tach works ) and now I have this problem. It will rev fine when the MAF is unplugged. I also unplugged the TPS but that didn't make any difference. see attached video clip.
Sent the ECU out today to ECM tuning for repair.
Solution
Switched the pins and runs like a top. :hellyeah: (and the tach still works !!LOL Thanks so much for taking the time to share your knowledge! And the thread "How to remove/replace pins in harness connectors" was a great help, even with the pics no longer available the explaination guided me thru. Made a tool to depress the tab inside the connector from a mini screwdriver filed down to fit. Kinda of a tight spot to work at it especially for 62 yr old bones LOL )
Solution
