KyDSM
- 192
- 2
- Nov 14, 2010
Down by the bay,
California
Ok so I'm doing a 90 to 91-94 throttle body swap on my GSX. I was following the write up on here on how to do it, but I'm having a issue with the wiring. My 90 tps only has 3 wires coming from it but also a wire coming from the plug connector for the throttle stopper. And the tps in the 91-94 throttle I believe to have a tps from a 2g or it at least has the plug from a 2g. The write up says the 90 tps wires and 91-94 tps wires will be:
90 TPS wires:
1 Green (IPS)
2 Green/Black (TPS Ground)
3 Green/Red (TPS +5 Power)
4 Green/White (TPS Output)
And the 91-94 wires:
1 Green/Red (TPS +5 Power)
2 Green/White (TPS Output)
3 NC (IPS on 2G sensors)
4 Green/Black (TPS Ground)
I only have Green/Black wire, Green/Red wire, and Green/White wire on the 90 TPS. On the 91-94 TPS I have Green/Yellow wire, Brown/Red wire, Yellow/Red wire, and Black wire which I believe are 2g wires. But I'm positive its a 91-94 throttle body. Would a 2g TPS work with this swap and if so how do I go about doing the wiring since I only have 3 wires coming from my TPS and different color wires coming from the other TPS. Thanks for the help.
Here is the write up I was following.
http://www.dsmtuners.com/threads/1990-swap-to-91-94-throttle-body.301466/
90 TPS wires:
1 Green (IPS)
