Swaping a 91-94 throttle body to a 90 possiable?
minimoose
297
Jul 24, 2011
Bourbonnais, Illinois
Hi all, currious if its possiable to convert/swap a 91-94 tb to my 90. I Cant get the isc off mine and its exspensive for a brand new one so I would like to convert to the 91-94 because there are alot of them at the yard near me. I know it bolts up and the isc looks like it has the same plug but the tps sensor is differant and Im currious if its possiable to snag the plug with the 91-94 tb and rewire my car for the new tps sensor. Thanks:confused:
You will need a 91-94 model fuel rail, and the TPS sensor pigtail to splice in.
if your gonna do that, get the non turbo tb. its bigger and better then the turbo tb's.
But this will also require differant Intercooler piping.....
1g turbo and N/T throttle bodies are the same size - 60mm. The only benefit is one less gasket since you don't use a throttle body elbow.
Yes true but the 1g turbo Throttle boody elbows are quite abit smaller then a Nt Tb opening.... even though the actual Tb size is the same
A turbo TB also allows you to use the TB elbow that will come with whatever fmic you choose.
