1987 mighty max 1g dsm
Last year I acquired a 1987 Mighty Max that was running but had a bad knock. I planned on throwing in a newer Evo motor to make a drift tuck. I started getting into it and it is in-fact a RWD 4g63 narrow block. The block is in great shape crank not so much, melted #4 bearingšŸ˜‚.
So I want to rebuild if I can with a stage 2 1g DSM DOHC from dsmparts not sure if that one will fit. Lower I was going Eagle forged 100mm stroker with Manley rods pistons bearings.
Will this work? Also need help sourcing wiring and intake/exhaust/turbo manifold
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
