16g will not build boost
tripph90
Jan 6, 2011
Richmond, Virginia
I put a TD05H (16g) turbo on im g2 Talon and it ran grate now wont build any boost past 0psi. Has any body had this happen?
i cant find a leak but havnt pulled the the turbo off to check the waste gate
is the waste gate sticking open a common problem ???
You dont need to pull the turbo off to check the wastegate, just put a set of vise grips on the rod for the wastegate and pull towards the exhaust side. It might take a bit of pulling. And if the turbo is used whether its a ebay 16g or mhi, carbon build up or rust can make the wastegate stick open
I don't know about the wastegate thing, although i have heard of that problem before, but in my experience it has always been from boost leaks. I really badly need to get an aftermarket FMIC. Check for leaks in obvious spots like the j pipe area, the lower ic pipes, and the couplers on the intercooler outlet and inlet. Also check the throttle body elbow and the bov. Good Luck
:thumb:
thank you everyone i will check it all out tomorrow. If anybody has any other advice please let me know. I will let you know when i find out what is wrong.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
