1G 16g auto w/ecmlink will not build boost to launch???!!!HELP
8urzr1
Aug 30, 2014
cincinnati, Ohio
Like it says I have a 91 auto awd mods/ 255,denso660 injectors/ecmlink v3/ 16g mhi/3in drag pipe/ stock bottomend/stock head other than kelford 272s/still running stock 1g maf/ stock smic... boost is set around 18psi no matter what I do I cannot get the car to build boost to launch effectively... 2.8 60fts aren't gonna cut it...any advice would be great! I believe it may be in the tune but im not sure,the car pulls great and runs great other than not being able to build boost offline... thanx fellas if I need to post some logs in order to help I will do so!
Thanks Cox Abele!!I have thought seriously about just doing a dry fogger seems to work well on my buddies car with our similar mods and a 6262 on a stock converter he builds 18ish psi offliine.
Also thought about throwing an ipt converter in it.The car sees the road everyday so I don't want to get to carried away with the converter id truthfully rather keep the stock tq converter in it..
I have not really had time to play with the tune yet but im gonna go that route first. I wouldn't think about changing the cams to stock as the cams are what brings this setup to life through midrange and wot. I had the same setup without the cams for a bit, when I did the cams it was a night and day difference for sure.Id say it makes another 30-50hp with the cams and that's before we changed the tune a bit.
Thanks for the advice I really appreciate it! Not sure why telling me I was running the wrong springs was gonna help me build boost outta the hole, ill post back after we change the tune...
