16g Water Line HELP!!
manahan21
Jun 5, 2012
Columbus, Ohio
Hello everyone,
First I wanna say that I have been searching and I just can exactly find what I need. I recently purchased a 16g turbo and it came with the water feed line still attached however the water return line is missing. The 16g is replacing a TD04hl turbo and the banjo bolts for the water return are too small. My first question is what is the exact size of the water return banjo bolt. I've seen M14x1.25, M14x1.5 and M16x1.25. Can anyone clarify this for me? Also, will I be able to reuse the water line I have from the previous turbo? Finally is there any other kind of fitting I can use as a coolant return line instead of the hard pipes. Something maybe similar to an oil feed line with a 90 degree angle or something like that? Please I need help asap! Thanks guys for all your help!
