Evo 3 16g help
nate95tsi
75
Aug 20, 2012
Woonsocket, Rhode Island
Hello DSMers,
Well I believe my t-25 is crapping out on me. When its cold it clacks a very little but goes away when it's warm. I checked shaft play and there is a little side to side, not back and forth. So I am in the market for a new turbo. I hate buying cheap sh** so I plan to buy the turbo from extremepsi. The problem is I recently bought the car so things are still a little tight. I currently have a walbro 255lph fuel pump, injen hard pipe, greddy bov, and FMIC. If I just put the turbo on with a tune will I be okay until I can swing the rest of the fuel upgrades? Also will I be able to use my injen hard pipe?
Thanks everyone
16g will be fine at stock wastegate pressure on a stock fuel system. You won't be able to go much past stock before you run into fuel cut.
