16g rebuild?
iboostdoyou
271
4
Feb 16, 2004
Parsippany, New Jersey
I just picked up a ported and clipped 16g a kid had lying around from his 1g project car for $40. For the price i couldnt turn it down. It needs a rebuild because of the play (i can pull the compressor wheel forward and back about an 1/8"). It also does not have an exhaust housing or a wastegate and actuator. How much roughly am I looking at to have the thing rebuilt, new exhaust side housing, wastegate, and actuator? :confused:
Rebuild kit alone is $100 from Forced Performance (or your reuilder). Housing, new, I am guessing $150-200. Wastegate is in the housing. Actuators are around $50. Used, you may be able to snag something off ebay cheap. Add in the cost of labor (unless you can do it...pretty simple), prolly around $60 h/r,times 2-3 hrs. Then figure $50 for balancing to protect your investment. So you have a final cost of:
$100
$150
$180
$50
$50
____
$530 (A new EVO 16G!)
Best case scenario:
$50 (two journal bearings, a thrust bearing/thrust collar from your local turbo place...there is one, i assure you...this is assuming you dont need new orings, etc)
$50 (actuator/housing)
$0 (you rebuild)
$0 (scibe a line along the nut, wheel,and shaft so it stays within stock balance..or else it WILL die again)
____
$100...not bad
im kind of new to this kind of stuff... but since the 14b is still a tdo5h, could i possibly use an exhaust housing from one of those and possibly reuse my stock wastegate?
