16g rebuild
98gst14b
453
Jan 24, 2006
Keys, Florida
Would it be possible to rebuild a knock off 16g with a true 16g rebuild kit, as to try to avoid failure again? IF so where would be a good place to buy one? THanks
You could try:
http://www.forcedperformance.net
and see if they offer a CHRA for the 16G's. Once you determine the cost you may find that's it's more cost effective to simply replace the turbo with an MHI but this should at least get you pointed in the right direction.
Good luck!
Andy
andymoraitis said:
You could try:
Good luck!
Andy
Your better off just buying a real 16g its like only $550 at dsmparts and it has the 34mm flapper and its ported. You probably have the 16g install kit so your good to go. :thumb:
andymoraitis said:
Turbochargers.com sells real MHI's for 459.00 if you want to save a pretty penny and still get a warranty.
I called turbochargers.com today and they sell the evo III 16g but it is not ported and does not come with a warrenty. But they do sell the EVO III GT turbo for the same price that is ported and comes with a 1 year warrenty. Is this what I should go with? Thanks.
Now you've done it LOL . You're going to get a lot of negative feedback on the EVO GT turbo but there are also a lot of folks who swear by it. Most of the complaints about the GT turbo are related to failure of the turbo itself within a very short time span. I think a lot of the negative remarks are strictly hearsay.
Ultimately it's up to you. The company does warranty the product and the GT turbo definitely pushes the numbers that a genuine MHI EVO III will.
Well from what I've been hearing its hit and miss with this turbo, not to start talking about somthing thats already covered in another thread but I don't think it would be a bad idea to try this turbo if it has a warrenty ;) thanks for your replies.
