htswmr6
- 0
- May 1, 2006
Carbondale,
Illinois
i am running a 16g turbo on my honda prelude and i am having an oil leak, i called a tunning shop that deals with mitsus and talked to them about it. they said that honda oil pressure is about 80 psi, and that is what i am running when i start the car up, at idle i am running about 20 psi which is normal. now the oil leak comes when i am running 5 to 10 psi consistantly and when i start the car. oil will drip if i start the car and it is running at 80 psi and the oil will spit out of the turbo and the car will smoke if i hold boost above 5 psi for a long period of time on the road. i was told by the shop that the oil pressure going to the turbo is suppose to be 55 psi at most is this true??
i am still running 80 psi at boost!!
