15 psi daily driver?
RedLinE-
Jan 2, 2005
Neosho, Missouri
I was wondering if it was safe to run 15 psi on the t25 as a daily driver, or will I run into problems using this setting.
LOL , dont go any higher because its a t25 :thumb: ... i think its pretty much done at 15 psi, MAYBE 17... but i dunno about that...
thats fine i run mine at set at that, it spikes to 19, but the t25 cant push enuff air and falls off so fast you really wont notice any differance.
i have mine set at 19psi. who cares. its a t25 with 117K!!!! im looking for a reasion to replace it!!
it depends on how much boosting you do around town. the t25 dosnt push enough air to hurt your engine. the rule of thumb is a t25 runs out of poop after 5500 rpms. with bost @ or over 15psi with channces of heat soaking the stock sidmount after multipul heavy pulls. but like i said. in moderation and short use.
I don't think that daily running a T25 at 15 psi is bad for the motor. I have mine at 12 because I hate the damn boost spikes (15>12). If you want your turbo to last for a long time then don't boost it at 15 every day because that will put a lot of stress on the turbo. T25's suck!
i boosted mine to 20psi on high setting on my boost controller, but around town i had it at 11ish. it did 20psi but around 5.5k it drops to about 16ish. and the t25 doesnt flow enough air to do any damage to your motor. but anything over 20psi and youre really putting alot of stress on the turbo. enough pulls at 20psi and its gonna give out one way or another.
