14b into a 20g? Really?
The CHRA has to machined out to accept the larger wheel, also you will need to replace the plate behind the wheel with one from a 16g or 20g.
No it is not true. The CHRA has to be machined to fit the 20g wheel. You can use that upgrade a big/evo3 16g.
Wow I started searching and I have a junk godspeed evo 16g laying around. Im thinking swapping out the 16g comp housing and comp wheel to the 14b. :D What else has to be swapped? the back plate?
