14b to 20g oil/coolant lines?
BLOHS7844
300
Oct 25, 2011
Appleton, Wisconsin
I'm gonna send my 14b in to Turbo Lab to be built into a 20g and I was wondering if I would need new oil or coolant lines. I already have all the coolant and oil lines for my 14b. I've gotten many conflicting responses. Yes I willrun coolant lines; I'm not gonna run a turbo timer. I have a 2g if that matters. Also in the process of getting supporting mods so don't worry about that.
If your car is already setup for a tdo5 turbo than no you will not have to change anything. If it is setup for a t25 than you will have to change the oil feed, oil drain, modify the coolant lines a bit and get a j pipe setup for the intercooler pipe.
