installer88
- 33
- 0
- Nov 11, 2007
Roswell,
Georgia
I will start from the beginning. My name is Jusitn, and I own an IS300 that is currently getting a 4g63 engine. I am performing 99% of the work since I am the head technician at a performance shop in Atlanta GA (Batlground Motorsports). The engine setup is an evo 8 block mated to a 2g dsm head. The engine is getting a 100mm crank, eagle rods, and ross 9:1 pistons. The head is getting evo 8 valves, and BC valves and retainers. The cams have not been purchased yet. Turbo is a garrett 35r, and the car will be powered on e85 via an AEM EMS. The transmission is a t56 out of an ls1 GTO. The bellhousing will be made by bill hincher, but he has not released one for the evo block yet. The car will be used 80% on track, but it will remain tagged and insured, for weekend drives. The body kit is a wald with 1" flares. I will be going wider. I am going to do some track testing with a friends ls1 IS300 to see if wider will be needed. Currently it fits 18x9.5 +25 on all corners, with 265 series tires. After this event I will know if I want to go wider or not. Brakes and suspension will be done after all the fabrication work for making the engine work is completed. Also the entire car will be painted during this ordeal. Here are the pics:
Back when she was stockish
Doing the flares
old beat up bodykit
pulling the 2jz
She had a twin, the white one now has an ls1
Doing the flares
old beat up bodykit
pulling the 2jz
. Thank you for the support.
