2GeNTSi
- 1,261
- 6
- Mar 1, 2003
South Sac,
California
I just finished installing my Autometer boost gauge today, yesterday I had my dad buy a t-fitting and connector then I went ahead and put the vacuum hose through an existing hole in the firewall. I teed it to the fule pressure regulator just like on Prostreetonline and today got some wires and used vampire clips to tap into the tailight.
After everything was finished I decided to go out and take it for a drive but first I let it warm up, once the car started it went to -10. I left my house and went on to a pretty open road and gave it a little throttle in 2nd gear and it went up to 14psi or so, so I was thinking that couldn't be right because I wasn't even at WOT. I drove slow to 7-Eleven (went to get some Sobe Green Tea) because I had low gas, and on the way back I went WOT for just a split second in 2nd gear again. I glanced at my gauge and it's pretty close to 20psi, I left off once I felt the tires just spinning and drove back home.
Now I don't have a MBC or any other sort of boost controller and I'm not sure if I'm getting boost spike or boost creep (whichever is the one where the boost climbs slowly after the set boost level) but what could be the problem .
Mods:
Dejontool 2 3/4 intake pipe (charcoal box and mbc nipple attached, breather filter on valve cover)
Dejontool Upper IC pipe w/ 1g bov and S pipe
ExtremePSi 3" Catback
One more thing, isn't the T25 only capable of holding about 16psi max?
Mods:
