kyler021
- 242
- 178
- Aug 29, 2023
Pasadena,
Maryland
Hey all,
I'm hoping to clear up some questions/concerns/misconceptions I have about catch cans and crankcase pressure. I've read many threads on catch cans, The 4G63T PCV system thread that everyone points to when you have a question about catch cans, and I've seen some setups for catch cans firsthand but I need more clarification. Because of course, there is varying opinions all over the place and I'm not sure what's right and what's wrong. What the 4G63T PCV System thread says that you NEED to do in order for gasses to effectively escape the crankcase, someone does the complete opposite, and it seems to work fine for them. Anyways, I'm rambling so I guess I'll just get straight into it.
So, I've been having issues with crankcase pressure popping out the dipstick, AND blowing past the seal on the oil cap. Throwing oil literally EVERYWHERE in the bay. For context, this is about 18psi at 6k RPM, on an Evo 3 16g turbo. This is also with the "Improved stock PCV Setup", minus the check valve as seen attached to this post, and on the thread posted above. Running 2 catch cans, and I've made sure they're hooked up properly about 100 times. I have high oil pressure (10w-30) too, I think it was about 65psi at 3k rpm, if that matters. I'm not sure what it goes to at redline but I'm guessing more than 100psi for sure. I've done a compression test too:
Cylinder 1: Dry - 115psi, Wet - 135psi
Cylinder 2: Dry - 125psi, Wet - 150psi
Cylinder 3: Dry - 130psi, Wet - 135-140psi
Cylinder 4: Dry -130-135psi, Wet 145psi
I have a new PCV valve, new catch cans, and new valve seals. I think I'm going to try to leave the hoses vented with no catch cans and see if that helps. I can't do this soon though, because I need a new timing belt since oil got on it.
Here are my questions and concerns:
If my current setup, the improved stock setup, isn't helping with crankcase pressure, is it worth trying to go for a bigger catch can/tank setup? Will that even help/work?
If the rings are worn bad, will a catch can even work to help the oil blowing out the dipstick and cap issue?
Some people say not to run the vented cans (including that thread), some people swear by them. Why do you think they are not effective/effective?
Some setups don't have the vacuum source to pull gasses out, and they work well without it, even though that thread, and a lot of people, say you absolutely need it to have an effective setup. Why is this?
If the catch can I want to use is vented, do you still need that vacuum source to pull out gasses and blowby oil?
If I wanted to convert to AN lines for a catch can, what's the best way to run them? If I'm just running 2 AN lines on the VC, what do I do with that PCV nipple on the intake manifold?
I was taking a look at the Forced Four billet oil cap adapter, and was thinking about running 2 lines to vent from there to a catch can, instead of using the stock nipple locations for the PCV. Is that a good setup or bad idea?
If I were to do that, what would I do with the stock nipples? Just leave them vented? Or cap them?
If I get the AN fittings welded in the stock location, I'm assuming baffles need to come out? What size AN fittings would work best?
If anyone has pictures of their setups and what worked for them, that would be awesome. I know that's a lot of questions, even if you have the answer to one of them, I'd love to hear it. I'm trying to gauge opinions before The Shootout, so I know how much money to bring and what to buy. I probably have more questions that I can't think of right now, so I'll add them when I think of them.
