Donv
5+ Year Contributor
- 51
- 6
- Jun 11, 2021
Parkville,
Missouri
Changed the master and slave I’m assuming pulling the trans is the next step
Personally, I would never buy anything with a 'stage' number as a selling point. Stick with proven names like ACT or Southbend via TMZ. Who recommended this kit?This is the clutch kit I was recommended
Tuner, he said he used it plenty of times And never had a problem but maybe I’m the lucky one that got a bad onePersonally, I would never buy anything with a 'stage' number as a selling point. Stick with proven names like ACT or Southbend via TMZ. Who recommended this kit?
They measure for me, but I still don’t understand it drove and shifted perfectly. And now it won’t go into gear when the car is onYour flywheel looks recently machined. Did you provide your machinist the step height and did they measure the step for you?
A local Napa shop f'd mine up by not measuring and I failed to call them out on it before leaving the shop. I shouldn't have blindly trusted their work.
Here's a good article if you are in doubt:
They happened to me many years ago from a respected machine shop. I took it back and asked him to measure the step in front of me and he was PISSEDYour flywheel looks recently machined. Did you provide your machinist the step height and did they measure the step for you?
. It was off quite a bit and I made him fix it right there. He kept telling me that the height doesn't matter
.So it drove perfectly and you had the flywheel machined and changed the clutch and now it's no good?They measure for me, but I still don’t understand it drove and shifted perfectly. And know it won’t go into gear when the car is on
What was the step height after machining?They measure for me, but I still don’t understand it drove and shifted perfectly. And know it won’t go into gear when the car is on
I’ll show you a picture of my old setup and why I changed itSo it drove perfectly and you had the flywheel machined and changed the clutch and now it's no good?
Isn't Spec a proven name?Personally, I would never buy anything with a 'stage' number as a selling point. Stick with proven names like ACT or Southbend via TMZ. Who recommended this kit?
