2G Oil leak
Here is a photo from the head
Where do both of these lines connect to?
Can you remove the check valve on the blue line and make sure it only blows out and not back in?
Okay and what about the other line with the check valve? You'll have to take it off and blow through it from the valve cover side and it should go through. Then blow through the other side and make sure it DOESNT go through. It's only meant to let vent crankcase pressure into the intake manifold but keep boost pressure from pressurizing the crank case.
I checked the valve it moves like you said
Okay so if your check valve is fine and your other line doesn't go anywhere.. the only sources of oil to your intercooler pipes would be your turbo.
Your turbo only get oil on the feed and return.. so either you have a bad turbo, (which sounds unlikely since you said it was replaced) or your oil drain is backing up because of overfilled oil, you're overrunning your turbo with oil pressure causing it to leak out a front seal of some sort or crankcase pressure. Those are really the only 2 possible options given all the process of elimination we just did.
Show us your oil drain please
I use the stock return line on the pan
Well that's fine if that works but it looks kinked or like it goes below the oil pan drain hole, and then comes back up. Oil won't drain properly if it's that way. The oil in the drain is mostly gravity drained so if it's not a good ALL DOWNHILL drain you're probably going to have drain issues.
Its like the good one it’s going like the bad one
I think we need a better picture of the drain line to see for sure.
Plus a 14an is pretty large and that's a fairly tight bend. I would be surprised if you made that line fit without a kink in it.
Can you get us a better picture of the drain line?
You see it right? Your return line dips below the level of your oil pan flange aka the "bad" setup. Oil pools in the line and causes enough back pressure to start pushing oil out the bearings instead of free flowing into the pan.
It might be difficult for that 14an line to be shortened enough without kinking. You might consider a kit like this instead, and make sure you shorten the line properly to eliminate any low spots like you have now.
  • For sale 2g 2GB Eclipse OEM Fog Light Bezels
    2GB Eclipse OEM Fog Light Bezels $45 + shipping & paypal feesYou must be registered to see...
  • For sale 2g 2G Sun Visor Set ( with home buttons for garage door )
    2G Sun Visor Set ( with home buttons for garage door ) $45 + shipping & paypal feesYou must be...
  • Wanted 2g Tan Door sill trim
    Looking for passenger and driver side door sill trim in tan color. Let me know what you guys...
    • Mahreeoh17
  • For sale 4G63 2g/1g Parts
    2g 1g parts
    • rEclipserGST
  • For sale Walbro 255 for 2g
    Selling a new walbro 255 with install kit for a 2g. Prefer zelle for payment but can do paypal.
    • tyvo98gsx
