Rattle on shifter in 4th gear
Levi Rademacher
May 12, 2026
Brainerd, Minnesota
I have a 2002 Mitsubishi Eclipse GS with a 4G64 and a 5 speed. When I bought the car I did a full clutch replacement but left the old flywheel because it looked clean, then the input shaft seal went out and sprayed tranny fluid all over my clutch. I replaced the input shaft seal and the bearings inside the transmission. Now ever since, in 4th gear, my shifter will rattle back and forth to the speed of the car like it wants to pop out of gear but when I put pressure on it, it goes away, but once I let off it comes right back.
Anyone know what this could be? I'm newer to the Eclipse stuff so anything helps. Thanks
Steve summed it up, we focus on 90 -99 cars. All are welcome. Ive been into some transmissions that would be similar. Did you shim any taper bearings when you did bearing replacements?
Dealer software is also available so you can lookup exploded diagrams, part numbers etc. Besides that I would recommend factory service manuals to conduct any repairs. They are much more detailed than generic Haynes manuals etc.
  • For sale 1g 1GB Eclipse Tail Lights
    1GB Eclipse Tail Lights $80 + shipping and paypal fees* not flawless but in very good shape...
  • For sale 4G63 FIC 1200cc Injectors
    FIC 1200cc Injectors $350 + shipping and paypal fees* injectors were cleaned 6/23/26You must...
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
  • For sale 1g Flip up headlight
    One red flip up headlight and the black trim piece for the other
    • Anthony Hornback
