Rattle on shifter in 4th gear
Levi Rademacher
May 12, 2026
Brainerd, Minnesota
I have a 2002 Mitsubishi Eclipse GS with a 4G64 and a 5 speed. When I bought the car I did a full clutch replacement but left the old flywheel because it looked clean, then the input shaft seal went out and sprayed tranny fluid all over my clutch. I replaced the input shaft seal and the bearings inside the transmission. Now ever since, in 4th gear, my shifter will rattle back and forth to the speed of the car like it wants to pop out of gear but when I put pressure on it, it goes away, but once I let off it comes right back.
Anyone know what this could be? I'm newer to the Eclipse stuff so anything helps. Thanks
Steve summed it up, we focus on 90 -99 cars. All are welcome. Ive been into some transmissions that would be similar. Did you shim any taper bearings when you did bearing replacements?
Dealer software is also available so you can lookup exploded diagrams, part numbers etc. Besides that I would recommend factory service manuals to conduct any repairs. They are much more detailed than generic Haynes manuals etc.
  • For sale 4G63 Frontline Fabrication V2 Billet Valve Cover
    Frontline Fabrication V2 Billet Valve Cover $750 + shipping & paypal fees* swivel AN fittings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
