Do I have a late 1g head or early 2g
Crazydsm1
May 3, 2026
Streamwood, Illinois
I’m thinking have a late 1g head but I need a little help here. On the side of the head by the thermostat housing it has a G6 -2 stamped on the head the water pipe branches back into the thermostat housing
The short block is a 6 bolt, that’s as far as I’ve gotten. I’m fixing up all the electrical issues as of right now and trying to figure out what trans is in the car as well
What do you mean by jdm head?
The 2 outer turbo manifold studs are m10’s and the rest are m8’s
The outer studs being M10 would tend to point to a 92 or later head but they could have been resized as well.
I mentioned JDM because of the early TB and CAS suggested there could have been a swap to a imported pull from Japan.
I happened to have a 2g head sitting on my 6 bolt, just to keep debris out, so I took a picture of the casting of it for you. ✌️
