92AWDHX40
Supporting Member
- 14,475
- 2,692
- May 22, 2007
Kalamazoo,
Michigan
Same here
Whoa whoa whoa whoa whoa..... hold on. Previous experience has led me to believe that once a shop starts working with other platforms they usually put the Mitsubishi's that started them in the "low priority" pile.This will expand into other chassis in the near future (RX7/Supra) is ones being looked into.
Haha that normally happens i do agree. I am still a DSMer and will always be one! Currently now rely on sales to put into R&D and other products so all sales help of course.Whoa whoa whoa whoa whoa..... hold on. Previous experience has led me to believe that once a shop starts working with other platforms they usually put the Mitsubishi's that started them in the "low priority" pile.
We'd like for that to not happen with you.
Have always wanted a Starion turbo to own. Love the look of them.If you want to branch out into other fantastic vehicles, the Mitsubishi Starion is a nice choice
The tensioners themselves are something that was being looked into slowly. We had no release dates or plans for those as of yet.Hello,
I apologize in advance for the slight change of topic, but has there been a recent update to the availability of timing belt tensioner arms and tensioner? I remember seeing some info on them some time ago, but don't ever remember reading an outcome. I visited the website and couldn't find anything either. Perhaps I missed it.
Thank you in advance,
Oscar
No that is not true.You still will need to machine the calipers. But these rotors will be a direct fit instead of using my rings to fit the mustang rotors
Not in the original aspect no, the non machined caliper will still need the Evo based wheel type.Is it known what offset wheel will be required to fit this mounting? Would this eliminate running the stock evo ET38 wheels?
It is quite mixed really. Most have the spacers and hate them. They wish to remove that and keep the offset and more material on the caliper. Some go the otherway around. It is all dependent on the person and what they see fit for them in both cost and fitment.Ok thats great! I suppose many like myself have already machined the caliper, and dont want new wheels but have interest in your rotor so they can ditch the hub centric ring the cobra rotor needs.
Older cars are a problem. Since the CTS-V is a GM part it may be around for sometime until Brembo stop getting the sales and they drop it as Brembo do. But should be around as long as GM use them.Does Girodisc or wilwood make any replacement rotor rings so you could just make a tophat for it?
I know what your saying, I love my evo brembo setup with the galant knuckles but problem is the new OEM parts aren't available/forever backorder or super expensive. I waited 3 months for the front evo dust sheilds from Mitsu and that was back in 2018!
Problem I ran into with the Talon was I wanted to keep it sigma platform and do the outlander big brakes but I've had bad luck with getting a good rebuilt caliper one had a super loose bleed screw and other the slider bolt was just stripped out one centric rebuild and other autozone. The parts are just old and it doesn't make sense to rebuild and recycle the castings anymore.
The CTSV is a great option because the OEM calipers are still available new last I checked.
Have rebuilt a few over the years inc my personal 2G as it was old even back then like 8 odd years ago. I even have that pump still kicking about once I removed it to go EpasPower to ya. Every time i rebuilt a power steering pump it never ended well
